[SOLD] 1973 Dodge Dart misc. parts including an 8 ¾ rear end, glass, bumper, grill, rally wheels, linkage,
Don R McCully
Los Angeles CA 90631
1973 Dodge Dart misc. parts including glass, bumper, grill, rally wheels, linkage, hubcaps, rear taillights, radio, dash.
I CANNOT FIGURE OUT HOW TO DELETE THE REAR END FROM TITLE LINE
HOWEVER THE 8 3/4 REAR END IS NO LONGER INCLUDED IN THIS LOT>
See link below for pictures.
Lot price $800. Local pickup in La Habra CA ONLY.
1973 Dodge Dart Parts - Google Drive
P1000205 Misc. trim and wipers
P1000206 Rear seat, side window glass, rear glass
P1000207 Front end bumper, grill, nose piece, headlight rings
P1000211 Rear suspension components, sway bar parts
P1000212 MOPAR Small block chrome valve covers
P1000213 904 Transmission cooler lines, fuel pump line
P1000214 A-body manual steering shaft
P1000215 Original dog dish hubcaps
P1000216 Windshield washer system parts
P1000217 Holley carburetor for parts, and additional rebuilding parts
P1000218 Misc. ignition parts, switch, coils, ballast resistors, turn signal ring
P1000219 318 heat stove
P1000220 Misc. nuts bolts, Main bolts, windage tray bolts,
340 exhaust bolts, oil filter plates
P1000221 Disc brake calipers and brackets
P1000222 Power brake booster and brackets
P1000223 Misc. visors, arm rests, plugs, locking gas cap, trunk lock, brake pedal cover, dimmer switch, clips, window cranks, ash tray, rear view mirror
P1000224 Misc. pulleys, automatic floor shift linkage, wiper motor, horn, flex plate, carb linkage
P1000225 Gas tank straps and bolts
P1000226A Rear taillight set
P1000226B Dash
P1000226C AM radio
P1000227 Stock trans pan and filter bolts, 7 blade fan,
trans kickdown lever, spring, and speedometer gears
P1000228 14” rally rims, trim rings, and centers
P1000228B 14x5½ BIG bolt pattern
