Chargedsix
Member
1973 dodge dart pro street.
Engine - forged steel crank 225 slant six 0.060" overbore. ARP head studs, main studs and rod bolts. Stock rods, trw pistons. Block is o-ringed with copper head gasket. Ported cylinder head with oversized ferrea valves. Cox bros aluminum roller rockers, clifford performance push rods. Custom comp cam, offenhauser intake, MP header. Performance carburetors stage 2 650 holley blow through carb. Supercharger store procharger kit with P1SC procharger at 15 pounds boost. Supercharger store water injection kit.
Transmission - A904 with shift kit and a 10" 3500 stall convertor
Stock mopar front supension with QA1 tubular upper and lower control arms. 4 wheel disc brakes. 4-link rear suspension with QA1 adjustable coil overs. 9 inch ford rear end with eaton tru track posi, Bears pro street axles, 4:30 gears
Mickey thompson sportsman tires 26x7.50x15 front and 31x18.50x15 rears. Centerline pro stock wheels
Serious inquires only. No trades. Asking $20,000 CAD car is located in chatham ontario canada
