Don R McCully
1973 Dodge Dart Sport
360 w/340 heads, 904 w/3.55 posi
This is a rust free California car.
Located in the Los Angeles CA area. Zip 90631
Price reduced to $9,500
This car was previous listed for $12,700
All reasonable offers considered.
Please watch replies to this listing for any further price reductions.
See link at the bottom for a full set of pictures.
"A" body "A" engine
87,500 miles on vehicle, Approximately 7,000 miles on modifications below.
Front End
Disc Brake Front end rebuilt w/graphite
Shocks KYB front KG4509
Front Sway Bar 1 1/8 "
Power Steering with Firm Feel Stage II steering box
Motor
Block 360 cid .030 over
ARP Rod bolts 144-6001
Pistons/Pins (forged) 9.2 compression Moly Rings
Melling High Volume Pump
Cam - Crane HMV-272-2-NC 693941
Steel Timing Chain Set Cloyes
Internally Balanced
Windage tray
Cylinder Heads
340 cid 2.02 intakes 1.60 exhaust
Surface .050 block side / .045 intake
Springs ISKY 3105-D
Hardened Keepers 4 groove
Adjustable Pushrods
Electronic High Performance Ignition
Spark Plugs Autolite 63
Light Weight Starter
Edlebrock Performer #2176 Intake
Holley 4-bbl 600cfm Carb 4160 LIST 8-1850
Air cleaner - stock open 340
Exhaust System 2 1/4" w/crossover
Sonic Turbo Mufflers
Transmission
A-904 transmission rebuilt
5.0 Kickdown Lever P4529023
Equipped with deep pan with drain plug
Rear End
Drum brakes 2 1/4" x 10"
Rear end housing 8 3/4 with 3.55 posi
New axles with big bolt pattern, green bearings, studs, lugs
Shocks KYB rear KG5511
Rear Sway Bar 1"
Rear leaf spring bushing set 5-2105 & 5-2101G w/graphite
Additional Notes
This car DOES NOT have A/C.
This car DOES NOT have Power Brakes.
The heater core is currently bypassed on this car.
This is a original paint car, the paint is 48 years old.
It has your normal parking lot dings on both sides.
The two more serious dings are shown in trunk lock area and RT rear tail light.
See photos of the Vinyl Top, Stripe, and Windshield defects.
This was originally a 6-cyl car the V-8 was installed with a V-8 K-frame.
The original small rear end was replaced with the heavier duty 8 3/4.
Sway bars were added front and rear.
New seat belts were installed, they are NOT ORIGINAL.
Dodge Dart - Google Drive Additional Pictures
McCully Dodge Dart - Google Drive
"A" body "A" engine
Front End
Motor
Internally Balanced
Windage tray
Cylinder Heads
Springs ISKY 3105-D
Adjustable Pushrods
Transmission
Rear End
Rear Sway Bar 1"
Additional Notes
