[FOR SALE] 1973 Plymouth Duster 318/904 (Reduced Price!)
NickCesca
New York
Rating - 0%
0   0   0
Middletown NY
Cash/ Bank check accepted!
Price: $16,000 OBO!
Facebook Marketplace link
I'll make it short and sweet, bought it from the original owner. 88k original miles.
Zero rust, two patch panels in the rear quarters behind the doors. Well done, no visible lines. Tons of new parts. Runs great, pulls hard.
Original numbers matching car, 318 motor, automatic.
Modifications-
Edelbrock AVS2 650 CFM four-barrel carb
Edelbrock 318/340 performer intake
Mopar purple cam
Flowmaster exhaust
MSD 6A ignition
MSD blaster coil
Recent work:
Pass ball joint
Pass Rotor
Driver Rotor
Pass pads
Driver pads
Pass brake caliper
Driver brake caliper
Pass brake line
Driver brake line
Four Cooper Cobra tires
New brake master
Oil change
Coolant flush
Spark plugs
Ceramic coating
Flowmaster exhaust
Rear diff fluid
Transmission fluid
Replacement transmission pan
Alignment
Pass wheel bearing
Driver wheel bearing
Alternator
Voltage Regulator
Battery
Wiper arm bushings
Headlight switch
Dash bulbs
Hood repaint
Edelbrock AVS2 650CFM
M&H Harness (Engine forward)
Air cleaner
Valve cover gaskets
Valve covers
MSD Blaster coil
Blueprint billet distributor
Blueprint wires
K&N fuel filter
Wiper motor harness
Front seat replacement
Hey guys this is real nice car. I was at his place a month ago and checked this car out. I realy don't like red cars. I believe this is a gold duster. If it was repainted gold, it is possible I would have bought it. Run great, sounds good, interior good. Realy a good daily driver kind of car.
Thanks nick
Thanks nick
Thank you! I appreciate it.
