MidnightSwinger
Resealed, painted, and a new NOS reverse light switch installed. Filled with Sta-Lube gear oil as recommended by Brewers. New output shaft seal. Ready to install and run.
The vin decodes a 74 trans, was told it’s from a 360 Dart Sport,which has the closest ratios for an A body A833.
One cover bolt broke on installation. The case is still sealed, and doesn’t leak. Comes with a new bolt from Brewers. Includes billet 1350 trans yoke at full price.
$750 Located in Woodland CA 95695
