modracerx
1974 DUSTER.... CLEAN FLORIDA TITLE ...CAR IS JUST NORTH OF TAMPA ....project started but son lost interest... .complete car ....its all there....runs and drives !!!!....this car has all of the right parts everyone wants ...power disc. brakes ( new booster ,new master cylinder. new calipers , new brake lines ) power steering ...big bolt pattern all around ... stock 318 with an edelbrock performer intake and their matching 4 barrel carb ...electric fuel pump...new exhaust with glasspacks and chrome tailpipe extensions....the interior needs a little work but the dash is good ...the dash pad is good ....nice steering wheel....the rear seat is mint ...the door panels are not bad ....split front bench is good except for a tear on the drivers side ...headliner has a small tear ...all the chrome is there ...great platform to finish ...here is what in my opinion it needs ...someone repaired the front floor pans but did not do a great job ...can get re-mans for 150, if you want them .....the drivers door hinges need to be re-worked . its a little loose and hits the left front fender ...there is a small amount of rust in the trunk, about a 4 inch by 4 inch spot in the bottom of the spare tire well, also another small spot on the right side, a few inches back from the wheel well.... does not need a trunk floor ...the rest of the body is really in good shape.....someone had already put rear lower patch panels on the car.....I do have multiple pix that I will try to get up on here asap.....you could double your money parting this out or finish the car to your liking....just need to get it out of my buddy's shop asap!.....a steal at $1950.00 but you must move fast or i will pay a body shop to paint the car and finish it myself ...thanks
