[FOR SALE] 1974 Plymouth Gold Duster 318
mopars4life
Northern VA
I have a nice 74 Duster Project that Has a lot of work done already on it. I have the fender tag and build sheet
It's Gold Duster with a lot of options and only 70k original miles. Trans appears to have been rebuilt. Runs well and has nice power.
-A/c (all parts intact)
-Rear speaker with fader
-P/S, PDB
-Sport bench seat with folding armrest
-Tahitian gold poly with gold interior
-Has aftermarket guages under the dash and a column mounted tach. All gauges work except the fuel gauge (suspect the dash gauge but can include another one with the car). Speedo cable cracked at the dash (was working until I pulled the cluster to check lighting - have another one that goes with the car)
-Dual Exhaust with fairly new mufflers
-Edelbrock performer 318/360 intake and 1406 carb with electric choke. The air cleaner on the car now I do need for another car. Has new fuel lines and fuel filter
-Front end completely rebuilt (tie rods, ball joints, idler and pitman, all bushings on control arms. Front factory sway bar added and I believe new torsion bars.
-New radiator
-New belts and fan clutch
-Rallye wheels added - tires are cracking but have good tread
-New front brakes - rotors, calipers, pads and hoses
-New rear brake cylinders and line on drivers side
-New Master Cylinder and Power Booster
-New gas tank and sending unit
-New shocks all around
-Brand new gold battery from advance last month
-New electronic distributor (looks like a MP one) and voltage regulator and box
-New Wires and plugs
-New blower motor
-Windshield has a new gasket
Body:
-Front floor were done as well as the trunk floor - needs some finish work and some minor patches on the very bottoms of the quarters - but much better than most that I have seen. Also some work on the cowl.
Extra parts that go with the car
-New carpet
-Extra cowl area and around battery tray (a battery leaked and caused rust). I did replace the tray already
-Misc interior parts
-Reman steering box and hoses if I get my asking price
What it needs:
-Windshield put in properly (had been taken out)
-Steering box (leaking)
-Put the new speedo cable on it.
I have all the trim for the car that is not on it.
Located in Northern VA , Craigslist link below. Asking $5500
1974 Plymouth Gold Duster V8
