[FOR SALE] 1976 318 / 360 timing cover
moparmat2000
Grand Tetons
I have a 1976 year model cast aluminum 318/360 timing cover for sale. Its been cleaned, degreased, media blasted, primered with high heat engine primer. All the threaded holes are in good condition without any stripped threads. Additionally all the small pitting corrosion you usually find in the water pump areas has been blasted to clean metal, and an aerospace structural aluminum paste has been used to fill and repair these cleaned minor defects, after which multiple layers of an aircraft fluid resistant epoxy primer has been applied to seal the water passageways from further corrosion issues. This is a nicely redone piece. A great part to replace your severely corroded original. Asking $75 plus the ride. Part located in Abilene Tx. I accept paypal, however i would prefer postal money order. PM me if interested.
Thanks
Matt
