1967Barracuda
1987 Dodge D150. Runs, Drives and rot free. This was my recent daily driver for a little while until I got a newer car and decided to go this route. 1987 is the last year for the slant six engine and it runs great. This truck will need a front brake caliper on the driver's side. This truck shifts hard, it will need a power steering pump. The mileage on the dash stopped because the speedometer cable housing bolt broke when I changed the tourqe converter in this truck. The tailgate opens by lifting slightly and pulling on the loose cable of the passenger side. The driver's door will shut fine if you pull the door to close from the middle of the door with the window down. Just typical old car problems but just minor tlc for the right person.Power Front Disc Brakes, Slant 6, A/C, Power Steering, Automatic, Regular Cab, Long Bed, 2 wheel drive, 8 1/4 rear differential open with 3.21 ring and pinion. Stock wheels with the hubcaps.
Located in Mardela Springs, Maryland.
$2600.00 starting bid on eBay no reserve
For sale on ebay 1987 Dodge D150 | eBay
