[SOLD] 2 360 ci LA Standard Bore Blocks
Rocket
CT
For sale are 2 1972 360 ci small block engine blocks. The casting number on both blocks is 3418496. Both are standard bore. This casting is the first production 360 block casting (1971-1974) and is rumored to have thicker cylinder walls than later castings. These blocks are a great choice to build a performance stroker small block.
The first block comes with stock main caps. Price $150. Prefer local pickup.
The second block comes with aftermarket 4 bolt main caps on mains 2, 3 and 4 and the stock caps on the 1st and last main. The 3 center caps will require installation.
Price $250. Local pickup preferred.
Can consider shipping if needed.
