2-bolt master
mopowers
West Sacramento, CA
What pushrod is needed for use with a later model 2-bolt master? I'm looking to replace a single circut master in my 66 and want to know what rod I need.
What you need is a plain manual brake pushrod. You might have to adjust the length (cutting, welding) for your application. That's what I had to do on my duster. Mopar performance sells an adjustable one. Make sure that when you have the pushrod at the length that you want, you put the little rubber ring in the end of the master to keep the pushrod from coming out accidentally. And I do mean accidentally.
