2 speed wiper motor install help?
northeastmopar
Massachusetts
Putting my motor back in. I was curious if the motor has to be installed in the "park" position when hooking the linkage arms under the dash to the motor and then install the actual wiper arms on the window in the parked position? If so, how can one tell if the motor is actually in the parked position??? Thanks......
Nope.
Just do not put the blades on until you operated the motor and it will find the park posistion.
