Dartfreak75
Restore it, Dont part it!
Let me start by saying this is my everyday driver dodge ram 1500 4x4 with 253000 miles I just replaced the rotors pads calipers and brake lines on the front in May. The back wheel cylinders, drums and springs in the rear were replaced 2 years ago and the brakes were bleed in May and have worked flawless since. And my master cylinders is completely full its not low that was my first thought. So here is the problem I'm having Thursday night i drove home and I had no problems at all Friday morning I got it to go to work and my abs and light was on when I got to the stop sign at the end of my road my brakes completely and violently locked up with the slightest brake pressure. So i turned around and came home and everytime I touch the brakes they lock up. I have done some research and everthing points to the abs module. But i was watching vidoes and reading and ppl say that their brakes worked fine with a bad module the lights just stayed on. Any brake experts on here? What do you guys think ? Thanks
