22” fan shroud
Tad
Not here
I’ve looked and can’t seem to find a 22” x 18” fan shroud for my 65 dart V8. Does anyone remake these?
Nope, not being repopped! They weren’t produced in great numbers (factory AC and HD cooling), they’ll be hard to find and expensive when you do.
Are you good with fiberglass?
The shroud doesn’t look that complicated so I bought a small sheet metal brake to see if I could form the corners. It appears to be doable but got sidetracked on other projects. Maybe I should get back on it since work on my 65 and 47 has slowed to a crawl
After you pop the mold your suppose to thicken the shroud on the inside with Fiberglass matt to give it more strength and thickness. The 2 coats of resin are just the starting point.
