[WANTED] 3 speed wiper motor and wires?
1970dartcustom
of the Moore clan
Broken Arrow, OK
Rating - 88.9%
8   1   0
I think I may as well ask if someone has a 1970-71 or so 3 speed variable wiper motor and wires in case my motor doesnt work... I will also take just the wires too if u have that...
This what your after?
Have the fuse box on it also.
Let me know at your earliest convenience
70dart, meant to add, that you should make sure you have under dash wiper linkages and bushings. Ive heard they are different from 2spd to variable. Just a heads up
Yes sir you are correct! They are different but if my old mind remembers correctly I believe he had the 3 speed motor but was lacking the wire from motor to the bulk head. I believe he should have the linkages and bushings already! BUT if not I have them still as well forsale!
