I didn't hook up the stator or field wires, just some 6ga going to battery, and it self excited, made proper voltage, and started pumping amps.
I don't have everything connected to run the engine for more then 30seconds, but....
Do I need those 2 other wires since it seemed to juice as expected or will the Devil show its face after the battery is topped off and those wires are not hooked up, and continue to run?
Its a duralast DL7127M 60 amp.
There's also a small post next to the heavier battery stud, not sure what that is all about. Most photos I see shows it missing, along with the 100 junk ones I have laying around. Seems it goes no where , ground or hot post with a continuity test
There's nothing sensitive on the machine. Just a 12v coil, points, battery, electric fan.
I might install some LED lights, but its hard to see oil leaks at night anyways.
Thanks.
Thanks.
