These are spool mounts bolted on a 340, with one spacer same as 360. They will also fit a 318 without the spacer using a shorter bolt which is included. All the bolts are included to use the mounts . They are used and should have the insulators replaced. Everything is glass beaded to bare metal, No rust to deal with $66.00 shipping included anywhere in the lower 48 states. I am located in Danielsville . Pa pick them up for $50
