318 carb linkage car return and transmission spring stud
1911a1
Active Member
Texas
Will one of the studs work on my Edelbrock performer carb for the transmission kick down linkage and for the two springs?
Home // Shop By Department > Truck & Jeep > Fuel > Carburetor Hardware > Carburetor Linkage Stud
I’ve found some factory looking ones on EBay.
The carb previously had a cobbled together machine screw
Also my throttle cable has some sort of plastic connector at the carburetor end. You can fit a machine screw through a hole to connect it up. I was wondering if there was something else that goes to it because that’s what it looks like.
The carb previously had is a 1974 Duster that came with a six banger.
You need the Edelbrock Mopar linkage adapter in order to place the stud in the correct position.
Edelbrock 1481 Edelbrock Throttle Lever Adapters for Performer Carburetors | Summit Racing
Then your factory-type stud will work fine. Just make sure you get the right one for an automatic. Your link above doesn't show anything.
69-74 Mopar 318 340 360 383 440 4-Barrel Automatic Throttle Cable Linkage Stud | eBay
