Dustedu2
out with 318, in with 422!!! 318 is forsale. Nice running 318 I know I will forget something so just ask. I am keeping the distributor, wires, coil, alt, and PS pump. Here is a video of it before 2.5" exhaust first run after install. asking $1000 in Dixon, IL. If you want the whole exhaust from head pipes back add $200. 2.5" to glass pack 2.25" out
Performer RPM 340 intake
Edelbrock 600cfm carb
Mopar 340 grind purple cam
not sure on rotating assembly (in it when I bought it)
9.5:1 compression ratio
360 heads milled to achieve CR
stock rockers
340 exhast manifolds (3614368 & 3418623)
TTI head pipes 2.5" (were welded but I will remove)
[ame="http://www.youtube.com/watch?v=0EBEvNxtUUk"]YouTube - 72 Duster 318 burn out[/ame]
stock rockers
