318 long block engine for sale
Slappy
Tampa Fla.
What I have here is a 318 long block that came out of my Demon. This engine has a new cam, lifters,timing set [double], water pump [Ibelieve 8 blade] and stock fuel pump. They have only been driven around the block a few times. I bet less than 10 miles. I would say this engine is good for a rebuild. The engine did let out a puff of smoke when initially started. This engine is pick-up only. I would like 225.00 for it. The engine is located in Fredericksburg Va 22408. Here are the cam specs. It is a sum-6900 from summit. Basically a mild cam.
int 420 duration 262
exhaust 442 duration 272
engine casting # 2536080318-2
I have some concern about "The engine did let out a puff of smoke when initially started." Can you tell anymore about this? Why did you take it back out?
Thanks, Sam
