[SOLD] 318 magnum cam setup
mikec
hampton
318 magnum cam 432 lift single pattern / timming set single row , chain stamped made in usa / valve springs,retainers,locks. all were new in remanuctured motor by ac/delco. Motor never run, I installed new cam setup in motor $190.00 or Best offer plus shipping or seperate cam and springs and timming setup
Have you checked the lobe lift to verify it is indeed a 318/5.2 cam? They are different than the 360/5.9. More desirable if it is a 318/5.2 cam. Would be sold already if that info was out there. GLWS!
i measured base circle at 35 mm and max lift of 41.5 to 42 mm leaves 7 mm difference to inches =.275 x 1.6 = 440 lift stock cam is 432 I think 360 cam is 410. from specs i've seen . cam came out of 318 motor , I still have motor and still not in lol
