[WANTED] 318 Sanden AC compressor brackets
Reed
Tacoma
Rating - 0%
0   0   0
I am looking for a set of brackets, pulleys, and bolts to add a Sanden AC compressor to my 1982 318. I currently have the non-AC alternator and power steering brackets, so I need all the AC compressor brackets and pulleys.
Anybody pull a set of brackets from their engine or have a core motor with these brackets that they aren't going got use?
The closer to Tacoma, WA the better, the cheaper the better. Thanks.
I have some brackets lying around that I can check for you, but I would need pictures of the ones you want please. Northern California
Belmateo- I am uploading the best pictures I have found of what I am looking for. I need the front and rear brackets for the Sanden style AC compressor and the corresponding alternator brackets. I also need the water pump and crank pulleys for an AC setup.
Browncar- can you post pictures of what you have? I need to make sure it is the correct kind of compressor.
I ran the pulleys and alt bracket through my blast cabinet and painted with high temp black. Off a 73 318
oooh, tempting, but I am really looking for the later Sanden rotary compressor, not the earlier v-twin compressor.
Ok, I was hoping they would work for ya.
If pulleys would work I'll trade those. I'm looking for a crank pulley with power steering. Good luck in your search
