[SOLD] 318 with new parts
Nathan56989
Active Member
ohio
Rating - 0%
0   0   0
I apologize in advance for the picture quality. The engine is buried in a corner of my garage.
I have a 318 that came out of my 72 dart. I was going to reuse it but decided to go with a big block. These new parts are brand new and have only been bolted on never started the engine with them on. If it matters the engine ran before pulling it and putting all these parts on.
Ideally I would like to sell this whole engine to get it out of the way. If you decide to use the engine the cam will need broken in. I did a compression and leak down test as well. I dont remember exactly spec for each cylinder but all compression were over 120psi on a cold engine without filling the cylinders with oil. Leak down, again, no oil dumped in the cylinders, was not over 15% on any cylinder. I used the leak down tester was used to hold the valves shut to replace the valve springs.
Cam - Jegs house brand cant remember which one but it wasn't anything gnarly just a step or two up from a factory cam
Lifters - comp
Valve spring - Comp
Valve stem seal - Comp
Timing set - Cloyes iirc. Double roller with new front crank seal as well
Headers - Hooker unpainted to fit with factory power steering. I have primed and painted them with VHT spray bombs
Intake manifold - Weiand dual plane
The bolts for all of this are new stainless allen head screws
I have over $600 invested just in the parts.
I'll sell the whole engine with all these parts for $500.
Located in Newark, Ohio 43055
