325 on 12"
DARTDALE
Hoxie AR.
Have any of you mounted a 325/50/15 on a 12" rim? If so what did the section width end up being? That is what I am thinking about doing to put under a 72 Dart mini-tubbed with springs under rails. I have 15 inch from inside rolled fender lip to the frame. The Prostar is 12 and 3/4 from lip to lip. It has 3 and 1/4 inch bs.I have a 9 inch to cut to fit.Not much room left. :glasses6:
The section width should be about 13.5" on a 12" rim. I ad them on a 8.5" rim. Bad idea. lOL
That would be my guess too, www.tirerack.com shows a BFG tire in size 325/50 R15 on a 10 inch rim as being 13 inches wide so 12 inch wide rim should put you near to the 13.5 inch section width.
