[SOLD] 340 Comp Hydraulic Roller Cam, like new
dodgedude
Kansas
Due to machining issues with my lifter bores, I will not be able to run a hydraulic roller cam in my engine. I have maybe 20 miles (less) on this cam. It is Comp Cams XR-286HR-10. Here is a link to the specs.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=648&sb=0
Made GREAT power in my stroker. I paid $337 from Comp, willing to take $275 shipped in the lower 48. I will also include the bronze dist. gear for no cost.
Thanks
first in line but need some pics if possible
Thanks..................................PETE................................
Sorry i apologize the one i was needing was XR268HR-10..... At this time i'll pass GLWTS.......
Thanks......................................PETE.................................
To answer some of the questions that I have received, I am adding the following:
My lifter bores had a VERY deep chamfer, which exposed the oil ring of the lifters at max lift, allowing oil pressure bleed off. I was able to get COMP to warranty the lifters, and was going to try a set of HUGHES lifters, but decided to go with a smaller grind and a flat tappet to eliminate the issue completely. Visit HUGHES ENGINES at the below link for detailed information of the block issue. No damage to any of the parts, just low oil pressure at idle.
http://www.hughesengines.com/Index/p...2&partid=26114
