matthew110366
Member
- Joined
- Aug 26, 2009
- Messages
- 14
- Reaction score
- 0
I have a 71 340 demon, 4spd, 3:91 ... it has a mild cam , X heads, I don't know what the cam size is , its not stock, on start up , it will idle with choke set , when the choke is off , it dies until warm after you feather the fuel, ... then when you get on the road and go from first to second it dies and then has a hard time starting again , but once it warms up your fine until you stop , sit for awhile then it s like it vapor locks and has a hard time starting up again ... is it a carb problem,it has a eldebrock 650 performer ( is it too small ) or a timing problem ... i'm at my wits end .... any suggestions
thanks
kevin
thanks
kevin
