340 std bore block date code 6-29-70
whodacudaman
michigan
anyone need a date code 6-29-70 std bore 340 block? no rotating assy--ive had for many many years and never built or used,lol---perfect block for a 70 cuda/challenger or wherever you might need an accurate date code 340 block!! if you have any questions--not sure what its worth but make reasonable offer and come get it! also have an a body dana 60 all done up real nice! have a few other smallblock items if anyone is interested--i have a 70 b body four speed that was behind this 340 and i have an a body 833 four speed as well (complete setup)
The Dana 60 is set up for std. a body width, b body or shortened? What gear set up and brakes are you running?
hoqdy! the dana is setup for std a body width and was completely redone with 4.10 gears and new posi of some sort and axels and new drilled/slotted rotors and new calipers/pads/rear cover and new e cables--whole nine yards!!
