[SOLD] 360/5.9 TBI engine
niceolddart
S.E. Pa.
From a 1990 4wd Ramcharger. Runs, has 134,000 miles on it & still in truck so you can hear it run. $400 OBO, you pick it up in 19030 Zip code area. I will remove it if any interest.
most likely a roller block with the good heads
Is that motor only, or with accessories
Price is for motor only; I am removing the main accessories, alt. & bracketry, starter, A/C compressor, P/S pump & brackets, fan, pulleys etc. Anything the engine won't need to run. (Except starter of course)
If you are really serious about the engine, I will sell it with all the accessories still attached for the same amount, $400 but, I will be taking it (The truck that is) all apart soon.
Let me know as soon as you can. Thanks
19030. I'm 30 minutes North of Philly, very close to I-95/295, Rt-1 & the Pa. Turnpike.
I will be starting to remove the motor/trans./transfer case this coming week along with the rest of the good parts from it.
