[SOLD] 360 diamond forged pistons nib
modart440
Rating - 80%
4   1   0
360 DIAMOND FORGED PISTONS NIB.These pistons are STD bore size.They have a 0.106 mini dome for a increase in compression.The comp height is 1.584 Depending on what is done to these pistons(and other combination variables) compression would be somewhere between 9.5 and 11:1 Pin diameter is 0.90 Cost is over 600.00 new 175.00 located near Toronto ,Ontario
Are these set up for the closed chamber heads (magnum type combustion chamber) or the LA open chamber?
