[SOLD] 360 For Sale - Apart
Cazbah362
Nevada
Pulled this from my 70 Challenger, was going to rebuild it and keep it to put back in, however have taken a new path when I found out the heads where cracked. So here is what I have:
360 Short block - 1976, factory bore. There is very little ridge on this, and the engine made real good oil pressure when running recently. Light carbon build up. Not sure what the cam is, however someone took the time to put in a Mildon gear drive, would assume they changed it at that time. Here are the items this comes with
I blasted, cleaned and painted the following parts:
Timing cover
All brackets
Edelbrock Performer
This comes with one of two carbs, you choose:
Carter AVS
Holley 600 Spread-bore
One of VC either:
Mopar MP valve covers
Or
Holley VC
Mopar adjustable rockers
Pushrods
cam
lifters
power steering pump
Alternator
Plug wires
Electronic Ignition Distributor
Car oil pan/pump, not sure if there is a windage tray
Working 727
Convertor -
Misc Hoses, belts, factory pulleys, all bolts which which where on it when I tore it down
Questions - PM please, AT this time I would like to sell it all once, no sense in parting it out YET.
Asking 800 OBO for everything
And for an additional cost of 250, will sell KB 191's .60 over
