360 Industrial Head Question - Valve Rotation
540slant6
Mopar SB Ripper
Berryville, VA
Hello Everyone, hope all has a great Turkey Day.
I just picked up a set.of 360 industrial heads, which appear to have the exhaust valve rotator? Can I switch the valve retainers to a typical LA and run my Comp 901 springs? I'm not familiar with the industrial stuff and nuances. Any help is greatly appreciated.
Valve keeper location with a 2 groove exhaust valve and using a rotator nets about a 1.500 spring installed height in used condition. This is using the non dampened spring for the comparison, seated pressure is 70 lbs. Then take the rotator off and install the intake retainer, still using the 2 groove keeper set up, you now have an installed height available at 1.600. But the original short stock exhaust spring now needs to be shimmed to rectify the loss of seated spring pressure OR select a spring that would net a sensible seated pressure, (not use the non dampened stock intake spring with the intake retainer and 2 groove valve/keeper combo that nets 120 lbs on the seat).
He can use stock intake springs and retainers with a new 4 groove exhaust valve to accomplish the correct math.
You're gona have to ditch the 2 groove valve because the available installed height is only going to be about 1.600 with your idea.
