ragtopfury
Fresh off a 125k mile 360. Drain plug is not stripped or cross threaded, no cracks or leaks, slight dent in the bottom.
The grime comes with it, as does the used oil pump unless you want me to trash the pump for you.
I imagine it is pretty common, so let's go cheap at $20 plus shipping. In person pick up in or near Manchester MD is always approved.
