360 magnum heads, intake?
mopardrt
Detroit
What intake is everyone using when using 360 magnum heads?
Not many choices for the magnum
M1 dual plane
M1 single plane
Eldebrock air gap
Cross-wind
Hughes will drill you heads for $80.00 and then you can run any LA intake.
M1 dual plane
M1 single plane
Eldebrock air gap
Cross-wind
I like the sound of that, only hughes in IL will drill the heads?
I made a jig to do mine, its not pretty but it worked great. I had maybe $10 in it. Now I can use both styles of intakes. Oh, I already had a 5/16 drill bit and a 3/8-16 tap for the bolts.
A couple of guys here made their own jigs to drill them.
Do a search on it.
I suggested hughes because they are close.
You typed faster than me, can you show a pic of the jig?
Here's mine. It's a little (ok, a lot) more robust than it needs to be, but I wanted to be able to use multiple times. It even has removeable bushings so the drill bit doesn't wear the bores out.
Any more pics available off that jig?
Here are some pics of mine, its not nearly as nice as the one above, but it worked lol. It got bent a little sitting around, but those spacers are cheap and easy to replace. I laid it all out on an old la head, and made some attachment tabs to locate it on the magnum head. Even had my 12 year old son practice some welding on it!
I just took off the Edelbrock air gap magnum manifold from the 360 I pulled out...Haven't listed it for sale yet, but I'm sure I live near you, so if you're interested, send me a PM!
