[FOR SALE] 360ci LA Short Block, 1977
gzig5
Mequon, WI
Nice clean 1977 360ci LA (not Magnum) short block from a Dodge, Mopar, Plymouth, or Chrysler car or truck. Not sure what it came from. It is original bore size, has not been cut bored out. Very clean, not rusty. May run as as-is but I can't say for sure. I have not taken caps off to check crank. Turned over and it looks good but I would assume it needs bearings. No cam. Pistons look good, no damage, and cylinders are clean and shiny but do have a ridge and should be bored if you plan for any performance. I planned to put a stroker crank in it to make a 408ci motor but plans have changed. Ready to rebuild.
$200 Might trade for other small block mopar performance parts or E-body parts/panels.
Local pickup only in the SE Wisconsin area. Will be driving to NE Missouri for deer season and may be able to meet along the way.
