chrisnben
MR Badfish
complete 470 build. Low deck 400 build to 470 Cu In. OR just heads, roller rockers & intake separately. details below:
All parts are brand new- save a few bucks here! I have assembled the pistons/rods/rings. 400 bore is .035 over. Block bored with torque plates to .035 over, zero-decked, ready for assembly. True 10.5/1 compression- pump gas 470.
All high-end parts; 440Source 3.90 stroker kit, CompCams solid mechanical cam 252/260 @ .050 & .598 lift (w/ the 1.6 rocker); 1.6 H.Sharp roller rockers, chromoly shafts & hold-down studs, cloyes double roller timing chain, 440S Stealth aluminum heads (bowls ported/worked and gasket matched to Eddy RPM intake, upgraded Comp beehive springs & 10 degree locks/retainers, heads are trued & corrected to 80cc; windage tray; 7qt pan; Melling HV oil pump; aluminum water pump & housing; stock valve covers & timing cover. Fluid balancer; ARP bolts throughout; Firecore RTR-CD ignition distributor & MSD 8mm wires. All you need is a carb!
This 470 should make +/- 600 HP/575 FT.LB. all day.
$6400. This is a grand less, plus it's all here- ready to go.
Stealth heads complete-rockers, springs, etc. & Eddy RPM intake $1900.
Engine assembly minus the top end $4450.
I can assemble for a fee. (crating/shipping extra- if needed). PM me here for more pics & details!! Located in Sun Prairie, WI.:burnout:
