[FOR SALE] 400 virgin bore, big block
Cudafever
Rating - 0%
0   0   0
$100 buck to the first on to get here. will not ship.
Ok for the details complete eng, including heads, intake and exh manifold and Flywheel.
Was running when came out of......71? ramcharger it has been in my garage for the past 10 years. Was going to build a stroker out of it someday..........Today it need to go because i can't take it with me.
There is some surface rust on cyl bores but the pic im showing, the clean spot, is were i rubbed the rust of with my finger. It has been in my garage cover up this hole time.
It is a steel crank 400, but as i said i was going for a stroker and didn't care that much.
It ran grate! HOW EVER! IT WOULD GO THRU A QUART OF OIL IN A HUNDRED MILES (Rings collapsed.) Didn't smoke that you could see, but, if you were behind, on the freeway you sure could smell it. Here's some pictures......Oh it resided at 82930 zip code.
I want it, but the drive from Indiana out there and back would kill the deal. If you decide to ship it put me first in line.
Thanks,
Tom
Will do, but that's not going to happen.
Have to much else going on to begin to make a shipping box sturdy enough.
Do you realize how much shipping would be on that big piece of iron!
Hoping somebody has a buddy that drive threw this area that could pick it out.
Is really a good building block........just can't take it with me.......and have been sitting on it for 10 years now.............don't have the time or money to make it run again.
Few racket straps on a pallet and Fastenal will ship it across the country way cheaper than you would think. I have shipped a lot of engines and pinball machines used them for years.
Tom
I just shipped a complete A833 trans from SC to NY for $124 through https://yrc.com/ . Terminal to terminal. Get a scrap pallet, strap it down, off it goes, money in your pocket and a FABO member with a smile on his face. I was impressed how easy and fast it was.
I ship heavy stuff everyday. You can ship on most common carriers for a "terminal to terminal pick up" dirt cheap
