[SOLD] 420 cu in small block short block
moparraceman
mansfield ohio
i have for sale a used very little 1967 340 short block 4.100 bore 4" stroke = 420 cu in it has eagle h beam rods ,diamond piston [ cc of your head with give you compression ratio could be from 10.5 to 13to 1]DRP #21 CASTING COST AROUND $800 FOR PISTON ,roller cam 620 lift ,and lifters ,lifters were kept in order the way they were position on can .brass gear on the pump drive for the roller cam balanced ,cam degreed .has oil pump with swing pick up, a body oil pan which has some dents in it but doesnt leak. front timing cover with good chain and gears, block has head stud bolts, and cosmetic head gasket which are encluded good set of heads could make 650 or more hp [ i didnt get heads in deal ] cleaned and painted.went low 10 s in a 70 duster bought it to put in my 64 dart but to much motor for street [got to watching street outlaws on tv and got carry away lol ]any questions let me know sellng for money to do my stock 340 selling cheaper because didnt get alot of info when i bought it $2200.00 obo short block and parts shown not holding first one that puts a deposit down gets it thanks also have front alum cover and front balancer for steel crank
ATTACH=full]1715070044[/ATTACH][
