440 build for a Dart
Darthemi75
Active Member
I found a 440 4-barrel in a GTX 1970 with 2843906 heads, and i want to make a good restoration of this engine. I am looking for a set of pistons in 0.30, but i dont know which are the best for my build project (brand and code). Because i dont want to loose the 375 hp.
The camshaft is in bad conditions, i think this MP 4452783 is the resto part...am i correct or no?.
Thanks
Are you doing the build yourself ? If you have a reputable engine builder, he should be able to guide into a nice, reliable build. Where are you located ?
I am in SOuth America - Lima Peru, and i need to import the parts because here doesnt found anything, thats the reason i ask someone to know the code or the best brand of pistons on 0.30 for a 440 Hi-perfo 375 HP (in the block said 1969).
Thanks
