charger426
Getting ready to start my stock bottom 440 build and I have a couple of questions. This is going to be my first build so some things are still a grey area for me. The two biggest question right now are in regards to my valve train.
How to you guys find out your pushrod length? From what I could gather I need to buy an adjust able pushrod, install some checker valve springs and use a solid lifter (even though the lifters I'm going to us are hydraulic tappets). Does that sound right to everyone?
What parts do I need to make my CAT Roller Rockers work (multiple part question)? I found a set of CAT roller rockers sitting on the shelf that my dad bought years ago. From what I've gathered the adjusters are pron to break so upgrading them is a must. I was looking at picking up a set of ARP rocker adjusters but even after filtering the thread pitch (7/16-20) I'm still left with 5 options to choose from. What other information do I need to know in order to determine the overall length needed and overall diameter?
These rockers came as rockers only, so I need to supple the shaft and other pieces needed to make them work. Is there any reason I couldn't just use the stock shafts and bolts from the iron heads I'm taking off?
Extra details in case they are needed:
78 440 block
TrickFlow Heads (TFS-61617801-C00)
Going with a Flat Tappet Cam with hydraulic lifters
78 440 block
