440 HP block, #906 heads, 440 intake MP Main caps
migsBIG
San Jose,CA
Nice bunch of parts for those whom need big block power.
1974 HP 440 block that was stored away since the early 1980's and was just recently disassembled. Std bore, low milage block looks like it could just be reringed and made to run. This is the good thick wall casting that folks would love to have for their stroker motor or restoration. Very nice, even have pics of every part of the engine, including the bores.
1972 440 HP cast iron intake
440 #906 heads, original and great for buildup. No rocker assembly
NS1 Mopar Performance 383-440 reinfocement forged steel main caps. These are much stronger and better designed that the factory caps and perfect for those wanting to strengthen their engine up. Only mild surface rust, but not a big deal as you will need to machine them to fit your crank to it. This is supposted the ad an additional 30% strength to the bottom end, so it's well worth the effort to install.
more pics at http://s130.photobucket.com/albums/p265/migsbig/planes/#!cpZZ7QQtppZZ16
Will sell :
440 hp block $325
440 #906 heads $50
440 intake $25
Mopar heavy duty main caps $110
or will sell all as a package of $399
San Jose, CA
can view more info/pictures on local craigs list
