5.2 Magnum oil pan
68coupe
I'm putting a 2001 5.2 Magnum in my 68. My old 318 oil pan won't work. So I need a 360 car oil pan? Thanks
What timing chain cover are you running?
I'm installing the Magnum complete engine. I hope to run everything including the serpentine belt - so to answer you question, I'm using the Magnum cover. Does anyone know of a center sump pan that is made for the Magnums?
the LA 360 car pan is what you need, the magnum 318 and 360 share the same oil pan
^^^ What they said...
I used a Summit stock reproduction gold irridite one on my 5.2 swap-fit like a glove.
