moparmaniacduster
Active Member
$3500 obo for everything. Located in Amherst NH.
5.7 Hemi
- From 2003 Ram 1500 w/ 116k miles. I heard it run myself very quiet and great oil pressure.
- Complete from throttle body to oil pan including coil packs, plug wires, exhaust manifolds, etc.
- Comes with complete engine side harness with ECU
- Comes with factory gas pedal/cable setup for DBW (1 year only setup)
- Have a set of Mopar exhaust manifold gaskets (for use with headers I never bought)
- Schumacher Motor Mounts for Slant 6 k-member
- Milodon mid-sump Oil pan/pickup (PN 31000)
- Note it does have a few broken valve cover bolts and exhaust manifold bolts (very common issue). Need to be drilled out and helicoiled.
46RH 2wd
- 46RH 3 wire version with lockup converter (Rarer than the 2 wire version)
- comes with stock pan and dipstick as well as stock truck lockup converter
A-body Borgeson Steering Box PN 800127
- Brand new still in original packaging, new costs $629
- the only power box that fits with the Gen3 hemi
A-body Holley Sniper EFI Fuel Tank PN 19-135
- Brand new still in original packaging, this includes pump and sending unit
- I will also include the regulator to run a 5.7 Hemi (Holley PN 12-876), also brand new
5.7 Hemi
46RH 2wd
