5.7 Hemi Heads Question
Carpainter
Bellefontaine
Hi everybody, I've got a question regarding the new 5.7 Hemi heads. Would these heads directly bolt onto an older small block mopar like a 340 or 360? If so, how do they perform with that combination as a carburated engine?
they don't bolt up, the configuration is very different. However, the 5.7 hemi does seem to run well with a carb set-up, several places make manifolds, including indy & edelbrock. you can delete the fuel injection, but still need ignition control, or a "chip Killer" distributor conversion, good option, but some of that stuff gets pricey.
