[WANTED] 5.9 Magnum Near Memphis
indirect_connection
Memphis, TN
Rating - 0%
0   0   0
I've been searching the local classifieds and not much has popped up. Figured I would post here before turning to a junkyard. I'm wanting a decent builder I can reuse the bottom end on with maybe new rings/bearings.
I will also need 4 barrel intake that will fit the Magnum heads. Jegs has the Chinese air gap for just over 200, but I may as well check for a used one first.
