6.1 Parts manual online or scans by e-mail
Buschi340
Wilhelmshaven, GERMANY
Guys,
I need to rebuild a 2010 6.1 Motor and want to replace all bolts, bearings, Piston rings and gaskets.
But to order that here in Germany from a dodge/Jeep dealer i need the part numbers which are not to find online.
Does some one has a source to download or scan his Manual and send by e-mail please???
I have found moparpartsoverstock.com to be helpful.
yep, i found almost everything except cam bearings.. ( brings me to a new Topic )
I still do not understand the main bearing codes A,B,C B is ok in the catalogue, but A&C are the same? doesn't work for me. One is under, one is oversize crank Journal
I Need C-B-B-B-C according to my crank shaft.
What is the correct P/N for the C coded bearings?
Thanks a lot!
