Cuda416
Alright, I left the title a little open in hopes of getting several things answered and others as I learn new questions...
I recently got a hold of what appears to be a factory (or at least over the counter) small block 6-pack intake. Has Chrysler, the part number and Edelbrock cast into it. Intake itself looks like it's in decent shape though I've not removed the carbs yet so threads are still in question.
starting questions are....
1. The center carb bowl is clearly not correct. Was there some reason in the past in which swapping them was "the thing to do"?
2. These are 440 carbs, was/is there a good reason other than it's what someone had on hand to run these vs the 340 carbs?
3. The choke pod on the center carb. Stupid dumb question, what it's interaction with the bimetal choke mounted in the manifold operation?
4. The outboard carbs are both list #4365, which I know is wrong since the front should be 4175, question is, how does that affect operation?
5. 4365 list carbs are N95, which I "believe" is California emissions related. What's different about them from non N95 carbs?
That's it for now. Thanks in advance!
