'61 Lancer/Valiant Hard Brake Lines? Need Help
doc540
Beaumont, Texas
I've looked in numerous catalogs and made many calls, but I can't find anyone who has pre-made hard brake lines for my '61 Lancer.
I need the hard line from front to back (along driver side frame rail) and the two hard lines running over the differential.
The flex hose between the main line and the rear T should be easy to find.
Before I have them fabricated, is there a source for pre-made hard lines?
Thanks!
did you try: in line tune, fine lines, etc.. there are 4 of those benders. they also sell everything you would need if you have to bend your own. I have a 62 lancer I will be doing the same routine on this fall or winter. I will change over to dual MC myself. and add 10 in drums. i'm keeping the 170. also I understand a 63 gas tank will work, but I havn't tried one yet.
yes the road toad parts are a challenge!!!
just get all the correct fittings, line, double flanging tool, and make your own. don't know a way though to apply the armour protecion though. if your lines are in tack, you could contact the benders they might agree to bend you some oem correct lines? road toads are so scarce, just no specific repop stuff for them....
Thanks, but I thought I'd ask about existing lines since I don't have a lift or the tools and have never fab'ed my own lines.
I realize to some it's a stupid simple project.
Armor protecion sold by Summit Racing. I also bought the benders that ONLY does the single size. A bit more expensive but it does a better job.
