these arms have the factory swaybar tabs that is unique to the 64~72 K-member and swaybar setup. they will also work with the earlier 62 & 63 cars.
they do not work with a factory 73~76 swaybar, however these might work with some aftermarket bars and the later K member.
these original socal rust free parts have been cleaned and checked and come with a Proforged control arm shaft kit (PN 120-10003) that consists of poly bushings with precision machined heat-treated greaseable pins, and new moog bump stops along with the factory adjusters, shock bolts and nuts & washers.
paint is raptor 1K rollbar and chassis paint
$400 + shipping from Los Angeles CA. PayPal preferred, zelle, postal money order, personal check with a hold or cash in person
** i'll be at the Mopars in May event tomorrow if you want to pick these up in person **
