[WANTED] 62 lancer left rear door
fivefivem
south carolina
Rating - 0%
0   0   0
looking for a 1962 lancer left rear door. any help or leads appreciated. also if someone could tell me if any other a-bodies door would fit? I know 61-62 lancer 4-door & wagon. any others? thanks in advance.
I have a Left rear door from a 1960 Valiant Wagon ,If you know if it is the same door ,I know the front door is not the same but I think the rear might be the same door .
The Door is actually off a 1961 Valiant Wagon ,I have parted out several Early 60,61 Valiant wagons .Thanks .
Where are you Located ? I am in Michigan I actually have a Nos Door LH rear and the used one ,$ 85.00 for the used one $200.00 for the NOS one .
Rear doors on 4 dr's and wagons are all the same, except for trim holes, on '61-'62 Lancers and '60-'62 Valiants. As someone noted in an earlier post Lancer front doors are interchangeable with Valiants but do have a different outer skin on them.
