65 Barracuda Lug Nuts
eengledow
Member
Oklahoma
I bought a new set of chrome lug nuts - Rock Auto indicated 7/16" / 20 was the right size.....they don't fit - they are to small.
What is the correct size?
if you have the original axelshafts with the small bolt pattern 5x4 then 7/16" / 20 is correct.
Maybe replaced with the big ones and 5x4.5" then the thread is 1/2"
OK, so I measured the bolt circle and they are indeed 5x4.5"
Does this mean that the previous owner changed out the rear end....it does have front disc brakes, so I know those are not original.
What year would the donor discs and rear end been? or range?
Either that or drilled the axles for BBP. Without pictures, there is no way to tell what you have.
No way to know without pictures. Could possibly be anything, but I changed mine over to 73 and later A-body BBP single piston.
Are the 5x4.5" thread size then 1/2" / 20?
Yes.
possible too that there is on one side RH and on the other LH when replaced from a later mopar. check the Threads accurate!
